Pipe Fluid Temperature Increase Due To Solar Loading
No replies to this topic
#1 HeemeshJ126
HeemeshJ126
Posted 06 April 2016 - 12:20 AM
Hi all,
I am currently at a bit of a cross roads and need some help in solving a problem.
I am investigating the temperature increase of a process fluid (-15*C) inside a un-insulated 32'' Sched 40 CS pipe exposed to the sun (ambient temp ranges from 30*C).
Could anyone advise as to what the base equations would be and general considerations in this case?
Thanks in advance! :)
  • 6,939 posts
Posted 06 April 2016 - 03:57 AM
Heemesh126,
Is you process fluid stagnant ? if not consider the xcelsheet attached .
Hope this helps
Edited by breizh, 06 April 2016 - 07:44 AM.
#3 Napo
Napo
  • 350 posts
Posted 08 April 2016 - 08:04 PM
HeemeshJ126,
The following link it can help you:
http://www.engineers...lator_12921.htm
Napo.​
#4 HeemeshJ126
HeemeshJ126
Posted 14 April 2016 - 01:24 AM
Thanks for the replies guys,
Both are very useful!
The fluid would be stagnant as it is in an instrument line, and the inner material would be liquid in this case.
Thanks!
