Relationship Between Increase Volume Of Water And The Pressure In Vacc
#1 Amiryazdanbakhsh
Amiryazdanbakhsh
  • 6 posts
Posted 12 April 2016 - 03:51 AM
If being water in the vaccum tomer how many time the volume of vapor increase...and if the pressure in higher or lower how the volume increase ؟
Is any equation between pressure and increase volume when we have water in vaccum tower
#2 samayaraj
samayaraj
  • 239 posts
Posted 12 April 2016 - 05:16 AM
Your query is not clear.
Do you mean, if you introduce a known quantity of water in a vacuum tower and you want to find out how much pressure would have raised in the tower?
#3 Amiryazdanbakhsh
Amiryazdanbakhsh
  • 6 posts
Posted 12 April 2016 - 05:23 AM
I want to know how volume of water in the different pressure in vaccum tower change?
For example one drop of water in vaccum tower how many time increase volume in 10 mmhg and how many time increase in 20 mmhg?
#4 latexman
  • 1,894 posts
Posted 12 April 2016 - 05:38 AM
Temperature must be known too.  Initial temperature of the water and temperature of the system under vacuum.
#5 Amiryazdanbakhsh
Amiryazdanbakhsh
  • 6 posts
Posted 12 April 2016 - 06:01 AM
Top temprature 7oc
Feed tem 370c
Bottom 330c
#6 latexman
  • 1,894 posts
Posted 12 April 2016 - 08:38 AM
At those temperatures and pressures (10-20 mm Hg), PV=nRT will be a good tool to tell you volume or density of water vapor.
