Hucky:
You need to have more basic data to make a decision on which type of head is appropriate, correct, or better for your application. You have to state the design temperature and pressure as well as the material. You also have to know certain basic and common sense criteria. For example, a hemi head is the perfect, and most strongest of all heads. However, it is plagued with welding problems and manual labor costs. Hemis are almost always used only on very high pressure applications and in large sizes (above 7-10 meters) where the cost and weight of the material is important.
Usually, the ellipsoidal head is the type most used in process vessels. It fills a happy medium in process vessel applications.
Read and study the attached information to learn more about vacuum design in pressure vessels. You don't have to study Mechanical Engineering, but it certainly doesn't hurt and it gives you great insight and engineering abilities to know ASME code and other important pressure vessel codes and information.
External Pressure Design for Vessels.docx 2.81MB
70 downloads
External Vessel Pressure.docx 37KB
50 downloads
Pressure Vessel Heads.docx 381.08KB
47 downloads
Cylindrical Shell 1.1.xlsm 38KB
53 downloads
Ellipsoidal Head ver 1.1.xlsm 101KB
49 downloads
Elliptical Head ver 2.11.xlsm 35.92KB
45 downloads
Flanged and Dished Head ver 1.1.xlsm 123.49KB
42 downloads
Process Vessel Design - Brownell 1959.pdf 9.26MB
82 downloads
