Hi All,
Any body know how to link SciLab with Hysys/Unisim. I want to receive flash calculation results in SciLab.
Posted 06 May 2016 - 01:00 PM
Hi All,
Posted 07 May 2016 - 01:03 AM
With Scilab, since you have access to sources you can link to any software exporting those values,
for multi phase equilibria I have used Scilab 5 with Prode Properties
other libraries as Coolprop etc. are available for specific applications
by the way, Coolprop ("www.coolprop.org") is a open source (C++) version of refprop,
while Prode Properties ("www.prode.com") is a more complete C++ thermo library
including direct solutions for many flash operations (vapor-liquid-solid) ,
there is a free edition but not open source.
Edited by serra, 07 May 2016 - 01:08 AM.
Posted 07 May 2016 - 07:59 AM
Thank you Serra,
I want to connect SciLab with Hysys /Unisim only can you please provide any information.
Posted 08 May 2016 - 03:23 AM
you may try co lan interface but,
1) slower
2) for solving flash operations, a much more expensive solution than above mentioned alternatives.
(just to mention a few points)
as alternative you can export results (no active link) and import them in Scilab
Edited by serra, 08 May 2016 - 03:24 AM.
