Ammonia-Water Ars Aspen Simulation Property Method
aspen absorption refrigeration ammonia water mixture simulation ammonia water eos
#1 Vergis K
Vergis K
Posted 10 May 2016 - 04:02 AM
hi,
I' m an undergraduate student in mechanical engineering in the Aristotle University of Thessaloniki in Greece. Right now im doing my final project in ARS and im trying to simulate ammonia-water cycles in aspen. I have problem with EOS and i really dont know which to pick. I tried peng-robinson, nrtl, Sour-RK, but not with good results.
Thanks in advance
#2 serra
serra
  • 311 posts
Posted 10 May 2016 - 04:29 AM
which mixture properties do not seem accurate ?
For water / ammonia (with a different software, Prode Properties)
I obtained reasonable values for H / S from Extended Peng Robinson,
while for VLE CPA did seem more accrate...
But nowadays there are so many models and options that it appears difficult to suggest one....
#3 Vergis K
Vergis K
Posted 10 May 2016 - 07:03 AM
I face problems in the VLE.
i have more 10% error using aspen.
My tools are a little bit limited.
What about Prode Properties?
#4 serra
serra
  • 311 posts
Posted 10 May 2016 - 09:25 AM
for a two components mixture you should be able to obtain a decent VLE data fitting with many models,
you may try for example a EOS with complex mixing rules (say PR+NRTL with WS or similar rules)
errors in VLE fractions should be below 10 %  once you recalculate BIPs for the speciifc operating range,
both Aspen and Prode include utilities for that,
Prode Properties is a thermo library, I utilize Prode mainly with Excel,
if you prefer a simulator go with Aspen,
if you like Excel (or similar tools) Prode Properties may be a good solution.
#5 Pilesar
  • 1,556 posts
Posted 10 May 2016 - 11:37 AM
Sour water thermodynamic packages are not accurate at high concentration (above 30%) but of the ones you listed the Sour-RK may have a chance to come close at lower concentrations. Ammonia forms ionic components with water and you no longer have a two-component system in the liquid phase. You may need to use an electrolytes package for higher accuracy if Sour-RK is not good enough. Can you be happy with 10% error? That does not sound so bad to me for your system and may be the best you can get.
Edited by Pilesar, 10 May 2016 - 11:39 AM.
