Two Phase Flow Pressure Drop In Perforated Pipe
#1 SheydaTamuzi
SheydaTamuzi
Posted 24 May 2016 - 04:40 AM
Hello everybody,
I want to calculate the pressure drop in a perforated pipe which is responsible for distributing a two phase flow in a stripping tower. The vapor volume flow rate is 68% of total flow rate. Perforated pipe diameter, the holes quantity and their diameter, vapor and liquid phase flow rates, their composition and density are known. Please let me know how can I calculate the pressure drop? (specially pressure drop through the holes) It would be appreciated, if anybody can introduce me any reference as well.
#2 Mahdi1980
Mahdi1980
  • 182 posts
Posted 24 May 2016 - 05:02 AM
Sheyda,
I have some useful information about sizing and calculation of perforated pipes for liquid and gas but not both, I mean two phase fluid.
So, I am afraid of being applicable such data for your case.
Please let me know if you require my data.
Mahdi
#3 SheydaTamuzi
SheydaTamuzi
Posted 24 May 2016 - 06:22 AM
Dear Mehdi,
In the case that I can find a two phase multiplier, it might be usefule. Please let me have the information.
Edited by SheydaTamuzi, 24 May 2016 - 12:08 PM.
#4 breizh
  • 6,744 posts
Posted 24 May 2016 - 06:29 AM
hi,
let you consider the attached document .
Good luck.
#5 Bobby Strain
Posted 24 May 2016 - 10:18 AM
Maybe you don't want to use a perforated pipe for this service. You probably should search for a more appropriate distributor, such as a vane.
