We are currently facing high velocity in a 15 km 30 " Sales gas pipeline. The sales gas is produced from an NGL recovery unit and is transferred via pipeline for domestic use. The high velocity is usually experienced while running the unit in 110 % capacity and on NGL rejection mode. This leads to more slippage of Ethane and Propane with sales gas and hence increasing the sales gas flow rate. The attached file summarizes the findings of the calculations I have done.
The company standards limits the (density x velocity^2) factor to be less or equal to 15000 kg.m.s^-2 and based on the actual density you can find the maximum allowable velocity. I believe Shell Standard limits the (density X velocity^2) factor to be less or equal than 20000 kg.m.s^-2 and the gas velocity to be between 10 m/s and 20 m/s.
Note that we are operating on rejection mode for approximately 1 month a year only depending the downstream requirements. Recovery mode calculations shows that we are at the limit in terms of velocity and (density x velocity^2) factor
Kindly let me know your views regarding this issue and whether the above is still considered acceptable with regards to other standards and what are the modifications (I.e. pipeline supports) that can be implemented to withstand this velocities.
Thank you in advance for your help.
Amine
