Screw Compressor - Non Matched Rotors Assembly
#screw compressors #machining
#1 Hassan seif
Hassan seif
  • 5 posts
Posted 25 May 2016 - 10:06 AM
Hi all
we have an oil flooded screw compressor that exhibits loss of capacity and noise after the compressor has been dismantled for maintenance it was found that the male shaft pinion (male shaft is driven by jackshaft) gear didn't have full contact on the shaft and noticeable circular scratches noticed on the shaft indicating that the pinion was spinning
Now my query is as follow
6 years ago we got a damage in the same compressor female rotors and we replaced male and female rotors
is it possible now to use that male shaft from the old rotor pair with the female shaft from another rotor pair
there is no strip seals on the rotor tips by the way
if the answer is no is it possible to remachine both old male and new female to be matched pair !!!
regards
  • 6,924 posts
Posted 25 May 2016 - 06:14 PM
Best to talk to the manufacturer .
