We have a BASF aMDEA based CO2 removal system in our ammonia maufacturing facility. Since long we are facing an abnormal behaviour of the system. The detail goes like this
The system when ever is taken in service either it is a hot or cold startup, it do not takes full load immediately and always gives CO2 slippage whereas all the conditions which are required for effecient CO2 loading in solution are met like lean & semi lean solution flows, Absorption column pressure, lean solution temperatures and concentration.
This condition prevails for around 1 month due to which plant remains at low load. After 1 month system gradually stablizes automatically on the same conditions and CO2 slippage decreases and even becomes Zero at times.
My question is about aMDEA solution CO2 loading behaviour, like any one have idea or experienced this kinda of aMDEA solution behaviour. Is this normal or not?
If not what could be the possibility like we have tried to increase its amine concentration to 45 %, we have checked the heat stable salts concentration in it and found normal. We try to keep the foam hieght at design conditions but still we face this problem after startups.
Is there any chemistry involved in this delay?
Your expert opinion is required.
