How to measure pH for a concentrated chemical mixture when the pH is not within the limit of the digital pH sensor and pH paper?
How To Measure Ph For A Concentrated Chemical Mixture?
Started by , Jun 14 2006 09:00 PM
Posted 14 June 2006 - 09:00 PM
Posted 15 June 2006 - 10:16 PM
pH of a concentrated chemical mixture is generally determined on 1 % solution or extract of the mixture in 7.0 pH water. For this what you do is, take 1 gm of the sample, add 100 ml of 7.0 pH water to it, shake vigorosly for 5 minutes, fliter to remove undissolved matter and determine pH of the filtrate by any method, indicator or pH meter.
Posted 17 June 2006 - 04:07 PM
QUOTE (P.K.Rao @ Jun 16 2006, 05:16 AM) <{POST_SNAPBACK}>
While this procedure may be usefull when you need to compare acidity or alkalinity of two different samples, it is of no use when you are interested in the real pH of the solution. But there is no generally accepted method of measuring pH in such cases. Too much depends on the solution composition.
I Have A Question From Himmelblau's Introduction To Chemical EnginStarted by Guest_Hindxxx//_* , 27 Jan 2026 |
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , 24 Apr 2025 |
Opportunities For Heat Recovery In A Chemical Process PlantStarted by Guest_tanyongboon1_* , 29 Nov 2024 |
Need Help For Utility Flow Rate Calculation For A Chemical ReactorStarted by Guest_Asisr_* , 12 Sep 2024 |
Separation Technology For Separate / Distillate Hcl From Water MixtureStarted by Guest_dpunnn_* , 11 Sep 2024 |
