Hello everyone i have some problems here
I want to set the pressure in the end of my simulation by adjusting the pressure of couple of streams which is made in the beginning of the simulation.
The independent variables are the pressure in the beginning, the dependent variable is the pressure in the end
here i attach my simulation's screenshot
Streams which are marked on red circle are the independent, and the stream which is marked on black circle are the dependent variable
https://drive.google...X0Zlam5fWjQwZ28
also, i attach my hysys simulation file
Any suggestions will be very much appreciated, Thanks!
Problem In Multiple Adjustment Hysys
Started by Grano, Jun 20 2016 08:12 PM
Lng ProblemStarted by Guest_guoyinyanliner_* , 10 Dec 2025 |
Thermosyphon Reboiler ProblemStarted by Guest_aliebrahem17_* , 22 Oct 2025 |
