Pump's Control
Posted 21 June 2016 - 04:32 AM
If a pump is connected to different viscous fluid sources and it is supposed to pump out of one source at a time, is it practical to close its suction motor operatd valve after the pump trip due to low liquid level?
Also, the pump has a temperature transmitter on its suction piping that is acting as a permessive that will prevent the pump starting when the reading is below certain temperature value. The line is heat traced. I have the following question regarding such interlock: if the tracing malfanctioned and the temperature dropped below that certain value, what will bring the fluid in the piping to elevated temperature and resume the pumping? can the tracing do that once it is rectified?
Posted 21 June 2016 - 06:14 AM
Dears,
Yes...
Also, the pump has a temperature transmitter on its suction piping that is acting as a permessive that will prevent the pump starting when the reading is below certain temperature value. The line is heat traced. I have the following question regarding such interlock: if the tracing malfanctioned and the temperature dropped below that certain value, what will bring the fluid in the piping to elevated temperature and resume the pumping? can the tracing do that once it is rectified?There should be an temperature alarm low to announce the operator about the heat tracing system malfunction...
Edited by fallah, 21 June 2016 - 06:16 AM.
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Equal Load Sharing And Anti-Surge ControlStarted by Guest_panoska_* , 02 Nov 2025 |
Control Strategy For 2 Air Compressors In ParallelStarted by Guest_panoska_* , 31 Oct 2025 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
