To
Cheresources viewers,
We are facing lot of problems with Titanium Dioxide-Anatase grade powder.
We charge the Titanium Di Oxide(TiO2)-Anatase grade powder into our reactor during our manufacturing process of our product. TiO2 being a powder (particle size of about 40 microns) sticks to the feeding hopper as well as to the screw feeder system. We are forced to pour the TiO2 manually into the reactor.
Our screw feeding system parameters are as follows.
Feeding rate 60-75 Kilograms per hour.
MOC of feeder SS-304
We will be happy ( profitable too!!) if one(more nos are also accepted!!) of the viewing fraternity help us and get rid of this problem.
Thanking You
ramnathsharma
Problems With Titanium Dioxide Powder Feeding
Started by ramnathsharma, Jun 17 2006 07:37 AM
Posted 17 June 2006 - 07:37 AM
Posted 23 June 2006 - 09:51 AM
You can contact "Cybernetik Technologies" in Pune. They are good at material handling. Maybe they can help you out.
Kiran G Parihar
Kiran G Parihar
Posted 23 June 2006 - 04:34 PM
ramnathsharma,
If you can accept the hopper and the conveyor also always retaining a small quantity of TiO2, then what would be wrong with continuing to use the materials handling equipment you already have in place? TiO2 will not degrade, so as far as I can see, you haven't defined a problem that would nullify this.
Doug
Doug
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
Calculator Problems In Pro IiStarted by Guest_kraemema_* , 04 Jan 2025 |
What Are The Differences Between Ph,orp & Chlorine Dioxide AnalyseStarted by Guest_Radha Krishnan Siva Kumar_* , 01 Apr 2024 |
Some Problems About Running Aspen HysysStarted by Guest_Mohammad3799_* , 05 Feb 2024 |
Problems With ProjectStarted by Guest_JArchy123_* , 07 Jan 2022 |
