Dear All
Would you please let me know how i can calculate H2S content in sour water which will be separated from Hydrocarbon in Atmospheric distillation column overhead accumulated drum?
Thanks in advance.
Posted 05 July 2016 - 01:01 PM
Dear All
Thanks in advance.
Posted 05 July 2016 - 11:19 PM
Please refer to IS 3025 (Indian Standard 3025). It is a standard chemical iodometric method. You can get the standard . at the address given below. The method is applicable to samples containing 1 to 30 mg sulfide. Vary the quantity of sample or dilute with distilled water if sulfides are more.
Bureau of Indian Standards
Manak Bhavan
9 Bahadur Shah Zafar Marg
New Delhi - 110002
Posted 06 July 2016 - 10:28 PM
Posted 06 July 2016 - 10:29 PM
Posted 07 July 2016 - 12:30 AM
Dear Reza,
As i know HCAMS able to do simulations but not for H2S. It's able to simulate sulphur distribution in product with your crude assay data base and cut range. I dont know if any software able to do the same for H2S.
Sulphur in crude able to form H2S in crude preheat (around 230oC).
Thx
Posted 07 July 2016 - 03:46 AM
I am not aware of any software predicting H2S in sour water.
Posted 07 July 2016 - 10:24 AM
Posted 07 July 2016 - 10:52 PM
If process simulator (for example , HYSYS, Pro II) , how can estimate H2S content in water.
SimSci Pro/II - GPSA sour water
AspenTech HYSYS and Aspen+ - API sour water
ProMAX - special package
But I wouldn't trust to all of them. In your case there is 3 phase and all of this packages are designed for preliminary sour water stripping modelling where only 2 phases exist. As per my experience lincesors rely on real plant data.
Edited by shvet, 07 July 2016 - 10:53 PM.
Posted 08 July 2016 - 09:45 AM
Since simulation is performed by PRO/II , i check the sour water H2S content in sour water with "GPSA sour water " property package in relux drum.
GPAS sour water equation of state can estimated H2S in sour water , but the problem is that the water content in hydrocarbon phase will be increase much more than excepted.
Posted 02 August 2016 - 01:54 PM
I have designed several sour water strippers with ProMax. It is the most accurate simulator I have found for this process. I know ProMax can model a three phase sour column, too. I have not done it, but I would recommend you call the ProMax guys for help with that.
