Calculating Flash Drum Temperature Using Bubble Point & Dew Point
flash temperature bubble point dew point flash drum design flash separation methanol-water seperation
#1 Hazem Hawwash
Hazem Hawwash
  • 16 posts
Posted 21 July 2016 - 05:49 PM
Hi All,
I am currently designing a flash drum for separating a non-ideal mixture of methanol and water. Pressure is being reduced from 8 bar to 1 bar. I have calculated the bubble point temperature and dew point temperature for the mixture. I have found the bubble point temperature to be 340.978 K (67.828 degC), and the dew point temperature to be 347.235K (74.805 degC). However, I am unsure as to how to calculate the temperature of the flash drum. I would be very grateful if somebody could shed some light on this.
Kind regards,
Hazem Hawwash
Edited by Hazem Hawwash, 21 July 2016 - 05:54 PM.
#2 Bobby Strain
Posted 21 July 2016 - 07:38 PM
You calculate the phases based on VLE and enthalpy. It's a trial and error process. Unless you have a simulator.
#3 breizh
  • 6,742 posts
Posted 21 July 2016 - 08:17 PM
http://www.questcons...properties.html
You may  use this resource to support your work .
Edited by breizh, 22 July 2016 - 01:50 AM.
#4 Hazem Hawwash
Hazem Hawwash
  • 16 posts
Posted 22 July 2016 - 10:48 PM
Thank you Bobby and Breizh, I took on your advice and it worked. I am now in the process of using Lewis Sorrel method to prove my previous calculations. However, I have varying relative volatility and it is not constant. As you may know, Lewis sorrel method uses y-values to calculate x. Is there a way of calculating the relative volatility using the vapour mole fractions only?  Much appreciated.
Kind Regards,
Hazem Hawwash
#5 breizh
  • 6,742 posts
Posted 23 July 2016 - 12:07 AM
Other resources I developed .
Consider the link attached too ! videos 42&43
https://cosmolearnin...energy-balance/
Hope this helps .
Edited by breizh, 25 July 2016 - 12:43 AM.
#6 Hazem Hawwash
Hazem Hawwash
  • 16 posts
Posted 27 July 2016 - 03:40 AM
I shall give these a go. Thank you very much.
