Hello, I am simulating a DWC configuration in hysys in a biorefinery process (Petlyuk), but the program does not let me connect a vapour stream that I extract from the main column to connect in the bottoms of the prefractionator because it shows a "Water Pumps Around are not allowed" . The DWC that I am simulating is an Extractive DWC. Thus, I need two condensers and only one reboiler. I have this problem when I want to connect the vapor stream from the main colum to the bottom in the prefractionator. I am using NRTL model and Hysys V8.4. If someone can give me some advice Please.
Pumps Around And Thermo Coupling In Hysys
Started by Magaby, Jul 30 2016 06:26 AM
Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
