Dears
Is it common practice to use a silencer in the suction line of a compressor?
What is the disadvantage of using a silencer in the suction of a compressor to reduce the noise?
Cheers
Mike
Posted 02 August 2016 - 04:33 AM
Dears
Cheers
Mike
Posted 02 August 2016 - 10:00 AM
No, it is not common. I've never heard of or seen one.
Expect higher horsepower if used. You will not succeed in reducing the noise level.
Parallel Compressor Setup With Uneven CapacitiesStarted by Guest_sinrem_* , 13 May 2025 |
