Hey people,
How can i reduce the stream pressure (say 150kPa) to atmospheric pressure while maintaining the same flow rate? Can i use an expander? The thing is that the flow rate must be maintained. Thank you very much
regards
Reducing Pressure
Started by Ben, Jun 22 2006 08:39 PM
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
