I am learning a new operations unit, (a Naphtha Hydrotreater unit specifically), which has a vertical baffle dividing the sump of a stripper column into 2 parts. What is the purpose of this baffle?
Purpose Of Vertical Baffle In Sump Of Splitter Tower?
Posted 07 August 2016 - 02:41 PM
Posted 07 August 2016 - 04:29 PM
I have no idea what you are talking about. But a sketch will remedy that.
Posted 07 August 2016 - 10:24 PM
Try to find answers in para 4.5 "Column Bottom Arangments" of Kister "Distillation Operation".
Edited by shvet, 08 August 2016 - 04:44 AM.
Posted 07 August 2016 - 11:47 PM
Posted 10 August 2016 - 02:43 AM
A baffle is often used in this way to ensure that the flow to the reboiler is as steady as possible. The liquid coming down the column is fed to the reboiler side of the baffle and the excess overflows to the other side which is used for level control and the bottom outlet. This means that any slight variation in the sump level does not affect the head on the reboiler - which could result in varying flow (and therefore varying heat transfer) through the reboiler.
Check which side of the baffle the downcoming liquid enters, and which side of the baffle has the outlet to the reboiler to see if this logic applies to your installation.
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
