Hi everybody,
I want to ask you the following question:
We have in our plant a tank containing such kind of residual oil fractions (IBP > 150 oC and S.G. > 0.94, water content max. 1%, atmospheric tank, two protection devices, one sample hole, steam coil present, MOT 75 oC, DT 100 oC).
At each 2 days we are pumping the product back to the unit, in order to recover the losses.
On 1st of September the pumping was started at about 70 oC and 6 meters for level height, and two days later, the pumping was finished, at 110 oC on the tank and at a level about 2 metres.
On next days, the temperature is continuing to rise up to 140 oC (probably the valve on the steam coil does not work properly), when, in a few seconds the tank roof was damaged completely, after one very strong and quickly explosion (no fire).
After, we verified the steam coil, that was not damaged. No possibility to introduce additional water to the tank (all the lines were verified).
Could temperature to determine such a high pressure, able to destroy the roof in a few seconds, at the lowest tank level, for this heavy product and for a water content at about max. 1%?
Thanks in advance.
