The Necessity Of Steam Condensate Drum
steam condensate recovery steam condensate condensate drum steam recovery condensate recovery
#1 S J
S J
  • 46 posts
Posted 27 September 2016 - 01:37 AM
Dear Sirs,
I'm process engineer, I have a question about steam recovery system.
In some projects, after steam is used for column reboiler , condensate is returned through condensate drum.
Please refer to case A in attached drawing.
In some projects, after steam is used for column reboiler, condensate is returned through steam trap.
Condensate recovery system including condensate drum is more complicated and expensive.
I'm not sure what advatages using condensate drum will have.
Please share any experience regarding advantages for using condensate drum and advise if we should use condensate drum
or trap is enough for recovering condensate after heat exchanger.
Best regards.
#2 fallah
  • 5,019 posts
Posted 27 September 2016 - 01:56 AM
S.J,
The criteria included in the following link may be a proper response to your query:
http://www.linkedin....216042640142336
#3 S J
S J
  • 46 posts
Posted 04 October 2016 - 10:51 PM
I tried to open your link several times,...but, I cannot open it.
#4 fallah
  • 5,019 posts
Posted 06 October 2016 - 12:43 AM
S.J,
Consider attach file...
  • Attached File  POT.docx   201.75KB   63 downloads
#5 S J
S J
  • 46 posts
Posted 06 October 2016 - 01:15 AM
Thank you.
Regards.
