Criteria For Meg Line And Pipeline
#1 processengineer1998
processengineer1998
  • 42 posts
Posted 16 October 2016 - 06:35 PM
Hi all
I am looking for some criteria for velocity and pressure drop/100m for MEG in order to perform line sizing for MEG line and pipeline.
I know general criteria for liquids such as what mentioned in TOTAL or others standards, but interesting thing for me is special criteria(velocity and pressure drop/100m) for MEG .
Please let me know if there is such criteria.
Edited by processengineer1998, 16 October 2016 - 10:21 PM.
  • 6,718 posts
Posted 16 October 2016 - 09:10 PM
Based on physical properties ( density , viscosity) you should perform hydraulic calculation . Use the search engine in this forum , you will find table or data .
Hope this helps
Edited by breizh, 17 October 2016 - 02:15 AM.
#3 processengineer1998
processengineer1998
  • 42 posts
Posted 29 October 2016 - 06:03 AM
thank you breizh
#4 processengineer1998
processengineer1998
  • 42 posts
Posted 17 November 2016 - 04:34 AM
Is there any concern about 0.5 to 0.6 m/s?
#5 Saml
Saml
  • 301 posts
Posted 17 November 2016 - 04:45 PM
If you are using SS (304L or 316L) you don't have any problem of corrosion, erosion, or passivation layer instability with MEG at usual velocities and moderate temperature (below 100 °C).
The main concern is pressure drop and the power required.
I don't see any issue with 0,6 m/s unless you have a limitation on available pressure drop. Plants that use MEG (like polyester fiber ones) normally use sch 10 SS piping for more than 20 years without problems or loss of thickness.
#6 processengineer1998
processengineer1998
  • 42 posts
Posted 28 November 2016 - 02:52 PM
Dear Samo
Thanks for your responce.
We are going to use carbon steel pipe in moderate temperature below 70C
