Chemical Treatment In Power Plant
#1 abhijit.bhole
abhijit.bhole
Posted 25 October 2016 - 03:41 AM
We need to provide Chemical Dosing Systems for power plant. Client needs Oxygen Scavenger, Ammonia, Phosphate & Corrosion Inhibitor Chemicals to be dosed. Locations shall be as below:
Oxygen Scavenger: For DO Control: from 0.3 to get 0.002
@ Condensate Pump Discharge - 325 m3/hr
@ Feed Water Suction - 238 m3/hr
@ Demin. Water Tank - 59.4 m3/hr
Ammonia: For pH control from 7 to 11.4
Phosphate: to get 4.7 ppm.
@ HP Drum: B/D Flow - 0.022 kg/sec
@ IP Drum: B/D Flow: 0.063 kg/sec
@ LP Drum: B/D Flow: 0.052 kg/sec
Corrosion Inhibitor Dosing for Closed Cooling System Water. Water Flow is 478 m3/hr
Kindly advice how to calculate dosing rates for above chemicals,
  • 6,754 posts
Posted 25 October 2016 - 03:53 AM
You should talk to suppliers of Chemicals ( big names ) .
To support consider the link attached :https://www.gewater....dbook/index.jsp
Good luck.
