hello
how can you calculate the time mixing of 250 m3 storage tank with a high viscosity liquid (350cp) using the jet mixers?
good luck,
mohsen
Posted 17 January 2017 - 12:29 AM
hello
good luck,
mohsen
Posted 18 January 2017 - 06:19 AM
Hi, Mohsen
Degree of mixing shall be calculated based on the degree of homogeneity.
Refer to the following material for reference: http://people.eng.un...s/8/Lehrer2.pdf
Stefano G Kim
Edited by sgkim, 19 January 2017 - 10:24 PM.
Posted 18 January 2017 - 05:17 PM
hope this helps.
Good luck.
Posted 18 January 2017 - 08:28 PM
Hi Breizh
I know this is off topic .. but can you provide the original source/reference paper for the "coil pressure drop" correlation you provided in this post
http://www.cheresour...op-calculation/
Many thanks
GF
Posted 07 April 2017 - 07:34 PM
Posted 10 April 2017 - 02:01 AM
hello
good luck,
mohsen
Refer the link below for jet mixing time:
https://www.cheresou...or-large-tanks/
What Can I Do With My Leftover Time In UniversityStarted by Guest_Acetimeter_* , 25 Jun 2025 |
Psv Release Rate Vs TimeStarted by Guest_stu_* , 30 Nov 2024 |
![]() Time Required To Heat Up A Fluid In A VesselStarted by Guest_panoska_* , 24 Jan 2023 |
