hi, everyone, I have to add an exchanger to my column ( a distillation column sub-flowsheet), anyone has an idea how to do it in the column Environment area. thank you.
Add A Heat Exchanger To A Column In Hysys
Started by titim, Jan 28 2017 11:03 PM
Posted 28 January 2017 - 11:03 PM
Posted 28 January 2017 - 11:25 PM
The simplest approach is to add heat input at the tray location. Otherwise, draw liquid to an exchanger and return it to the column.
Posted 04 February 2017 - 07:18 PM
In this case you can try to model the same column without condenser (see Palette) and then to add exchanger, drum and pump. For first iteration take composition and conditions from stream "reflux condenser". Use the "Recycle" to return flow to column.
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
