Hi All,
I am trying to model the steam reforming of ethanol to produce hydrogen, which fluid package should I use on Aspen HYSYS.
Posted 13 February 2017 - 10:17 AM
Hi All,
Posted 28 February 2017 - 12:28 PM
Hi there
I was also coincidentally interested in this type of technology since some months ago. I have read a couple of papers regarding the experimental procedures and special catalyst developments, but none of them seems to deal with the mathematical modelling yet.
http://www.sciencedi...926860X08007424
https://www.ripublic...dv4n3spl_02.pdf
http://www.scielo.br...422014000500016
As far as i have checked, the peng-robinson correlation seems fair for the steam methane reforming, but for accounting for the ethanol-water interaction, i am not sure this correlation is still accurate. Moreover, SRK should not be used for non-ideal chemicals such as alcohols, acids or other components; they are more accurately handled by activity models or PRSV EoS. I would think it would be even better represented by using the PC-SAFT correlation. In any case, the ethanol-water mixture is highly non-ideal and the ethanol reforming process is also achieved at high temperatures. The additional amount of oxygen in the ethanol makes the chemistry a bit more complicated than just reforming oxygen-free methane.
Dan.
Edited by danielrap, 28 February 2017 - 12:29 PM.
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
