We have a question about design a cooling system with Propylene Glycol solution 52/48 at various temp and hence various viscosity values. System description: Propylene Glycol solution 52/48 will use as a cooling media at a Generator cooler. The Propylene Glycol will cool the hot air circulation at the Generator. Hot Propylene Glycol will be cooled by a dedicated air cooler consists of several fans and circulation pump.
The system is designed for 80F where 52/48 solution viscosity is around 3 cps. However min ambient temp at the area is around -30F with solution viscosity of about 250 cps.
Our concern is about start up of this system at a cold day (-30 F). Do we have to design the circulation pump for Propylene Glycol solution at -30F with 250 cps? Maybe we could circulate only small amount of Propylene Glycol solution at start up in order to reduce viscosity of the solution? Does any body have experience with such sys? What about the circulation pump motor? Does it need a heater or to be over sized?
Thanks in advance
Propylene Glycol Solution As A Cooling Media
Started by bmicky, Jul 20 2006 02:03 AM
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Any Solution For Unstable Run By Hysys?Started by Guest_AnbIran_* , 29 Jun 2024 |
