High High Level Of Tank
#1 DANA-IF
DANA-IF
  • 160 posts
Posted 23 February 2017 - 03:31 AM
Hello friends ;
I'm using pipeflow expert to do hydraulic calculation and like to set the tank level at HHL(high high level).
I'm wondering please how to calculate the value of HHL .
The data for the tank are :
capacity = 1000 m3
height= 10 m
flow rate= 100 m3/hr
REGARDS
#2 Chemitofreak
Chemitofreak
  • 292 posts
Posted 24 February 2017 - 01:18 AM
Tank levels are finalized on the following basis:
Tank Bottom - LLLL: Based on the NPSH requirement of the Pump or based on the suction nozzle size
LLLL - LLL: Time required for the operator to take corrective action. It is based on project philosophy
LLL - HLL: Working volume of the tank. Storage capacity required.
HLL - HHLL: Time required for the operator to take corrective action. It is based on project philosophy
HHLL - Top Curb Angle: Based on overflow nozzle size
Hope it solves your query.
#3 DANA-IF
DANA-IF
  • 160 posts
Posted 24 February 2017 - 05:38 AM
Chemitofreak:
This is height differential , I'd like the height from tank bottom to HHL
#4 samayaraj
samayaraj
  • 239 posts
Posted 25 February 2017 - 09:19 AM
Below link may be useful
https://www.cheresou...6-tanks-basics/
#5 Chemitofreak
Chemitofreak
  • 292 posts
Posted 03 March 2017 - 03:21 AM
Chemitofreak:
When you add the height differential you will get height from tank bottom to HHLL.
Hope it answers your query.
#6 breizh
  • 6,805 posts
Posted 03 March 2017 - 04:44 AM
let you consider this paper with example/data/explaination  to support your work.
