Vle Data Thermodynamic Consistency Integral Area Test
#1 g3wtter
g3wtter
  • 10 posts
Posted 26 February 2017 - 10:42 AM
hello,
I am trying to do this area test but the values of ln(gamma1/gamma2) are all positive so when I plot a graph of ln(gamma1/gamma2) vs x1 I get only one area above the x-axis and no are below.
Does this mean the data set is thermodynamically inconsistent or am I missing something?
I have also done the van ness point to point test which said that the data is thermodynamically consistent.
any help would be appreciated
kind regards
#2 g3wtter
g3wtter
  • 10 posts
Posted 26 February 2017 - 10:47 AM
the picture got lost when posting this for some reason:
#3 MrShorty
MrShorty
  • 519 posts
Posted 27 February 2017 - 10:29 AM
From what I can gather from the derivations of the standard area test (Herington test), the criteria that the total area should be 0 applies to data that covers the entire composition range from 0 to 1. Your data extend from 0.05 to 0.3.
#4 g3wtter
g3wtter
  • 10 posts
Posted 01 March 2017 - 05:01 PM
Thank you very much for your input Mrshorty
does this mean that the area test is only applicable for experimental data over the entire mixture range or can I use a correlation model to generate data points over the entire range and then apply the test?
#5 MrShorty
MrShorty
  • 519 posts
Posted 02 March 2017 - 10:20 AM
I see no reason why you could not use a correlation model to generate data points over the entire range. However, a good correlation model should be thermodynamically consistent, so it should pass the area test. One might question whether such a test truly tests the measured data for thermodynamic consistiency, or if it tests the correlation model for thermondynamic consistency.
In their book Molecular Thermodynamics of Fluid-Phase Equilibria Prausnitz et al. suggest that the most reliable test for thermodynamic consistency is to use the Gibbs-Duhem equation to compute the 4th variable (y, for example) from the other three variables (P, T, x) and see how closely the computed values match the measured values.
