can we export stem ejector model from hysys to aspen plus?
Can Steam Ejector In Aspen Hysys Be Used In Aspen Plus?
Posted 16 March 2017 - 11:27 AM
Posted 16 March 2017 - 12:12 PM
What are you trying to calculate?
Ejectors are very difficult to rate/size using the simulation software. The only reliable answer will be from the vendor.
Posted 16 March 2017 - 10:11 PM
i want to simulate a plant in aspen plus and for that i want an ejector.
Posted 17 March 2017 - 03:56 AM
Presumably you have sections of the plant operating under vacuum? If so, why not just set the pressure of the corresponding units to what it should be (at a vacuum) and proceed with the simulation? You don't necessarily need the ejector to set a pressure on a particular column or vessel.
Posted 17 March 2017 - 05:08 AM
yeah, but in actual plant i would require some equipment for that vacuum to be created and want to know the size of the equipment(may not be very accurate but an estimate).My question is that aspen hysys has steam ejector model in it, can i export this model to aspen plus.
Posted 18 March 2017 - 11:18 AM
From your A+ model, if you can get the flow rate of non condensibles, and you have an idea about the steam you want to use as the motive fluid, the size of the ejector can be obtained from a manufacturer. A vacuum pump can also be considered unless your plant has excess steam.
Posted 09 October 2017 - 07:34 AM
Posted 04 November 2017 - 07:30 AM
Yes there is a Ejector plugin that you can register in HYSYS then you can use it in simulation
Posted 07 January 2021 - 05:23 AM
Hello
I am working on Hysys 12 and there is not ejector module in this version! I think the last version using ejector was 6.2. How can I simulate ejector part in Hysys 12??
#10
Posted 24 January 2021 - 12:31 PM
It's an usupported addin, you might still be able to find it on the AT support site as a download. It cannot be transferred to A+. question remains why do you need it?, just fix the pressure.
#11
Posted 04 June 2023 - 09:37 AM
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
