Control Valve Sizing In Complex Hydraulic Circuits
#1 Vegeta
Vegeta
  • 133 posts
Posted 24 March 2017 - 03:47 PM
Dears,
If there is a process requirement to install a liquid level control valve followed by a temperature control valve upstream of an exchanger on the common discharge header which then branches to multiple lines that go to different destination with a flow control valve on each branched line. How to assign and distribute the available pressure drop to the level, temperature, and flow control valves?
#2 cea
cea
  • 108 posts
Posted 24 March 2017 - 11:13 PM
Can you put pictorial presentation of scheme envisaged? P&ID with stream data will be ideal.
#3 Vegeta
Vegeta
  • 133 posts
Posted 25 March 2017 - 01:59 PM
Hope the attached sketch can help.
  • Attached File  PFD.jpg   41.01KB   1 downloads
Edited by Vegeta, 25 March 2017 - 02:00 PM.
#4 breizh
  • 6,942 posts
Posted 25 March 2017 - 06:38 PM
Hi Vegeta ,
Your system is very complicated , lack of "freedom" ..
You may consider a more simple arrangement :
   level control to stripper acting on the discharge to storage tank , no split range ;
  TIC acting on the coolant , not on the flow from the column  ,if possible
   FIC , nothing special
My view
#5 shvet
shvet
  • 135 posts
Posted 26 March 2017 - 12:38 AM
My view
Edited by shvet, 26 March 2017 - 12:45 AM.
