Natural Gas Plant Turndown
troubleshooting natural gas turndown
10 replies to this topic
#1 wafasaleem
wafasaleem
  • 17 posts
Posted 26 March 2017 - 03:15 AM
Hi friends,
This query is just for educational purpose. Suppose a natural gas processing plant consisting of sweetening(amine), dehydration(JT) and sulfur recovery(Claus) units are designed for a turndown capacity of 40% feed gas. During the course of gas extraction, the pressure and flowrate of the raw gas gradually decreases and at some point reaches the design turndown value. what should be the changes and troubleshooting to be done for the plant if the gas feed rate is below the design turndown?
#2 Napo
Napo
  • 350 posts
Posted 26 March 2017 - 02:14 PM
Wafasaleem,
You need to install some recirculation lines for to have the operatives parameters of production (quality), you need a low pressure system for to have recircualtion system permit the plant operation specially if the charge is variable.
I attached you a simplified configuration of our plant.
Napo.
#3 wafasaleem
wafasaleem
  • 17 posts
Posted 30 March 2017 - 06:13 AM
But is there any way of reducing the turndown ration to say 20-25 % ?
#4 Napo
Napo
  • 350 posts
Posted 30 March 2017 - 08:16 AM
Wafasaleem,
With this configuration our plant Works between 110% and 10% of the charge, obviously you need other design parameters.
Napo.
#5 wafasaleem
wafasaleem
  • 17 posts
Posted 02 April 2017 - 06:20 AM
But this is a different process from what I have mentioned in my topic.
#6 Napo
Napo
  • 350 posts
Posted 02 April 2017 - 10:05 AM
Wafasaleem,
I gave you only a "real application" about your "educational purpose", then you can put more or less units and work under this scope if you want.
Maybe other colleagues will give other "solutions" about your question.
Napo.
#7 Root
Root
  • 293 posts
Posted 02 April 2017 - 08:01 PM
once you are going to reduce the load on plant you need to consider following points,
  1. Heat medium duty.
  2. cooling duty.
  3. mostly rotating equipment are not recommended to operate below 30% of their design.
  4. vessels level controlling.
Cheers
#8 wafasaleem
wafasaleem
  • 17 posts
Posted 11 April 2017 - 12:36 AM
Thanks root,
How do we manage the pumps and any rotating devices in such a situation?
#9 shan
shan
  • 692 posts
Posted 11 April 2017 - 06:32 AM
Recycle to meet your minimum flow requirements.
#10 wafasaleem
wafasaleem
  • 17 posts
Posted 15 April 2017 - 11:49 PM
Sorry, but could you make it clear? what is to be recycled?
#11 Pronab
Pronab
  • 166 posts
Posted 16 April 2017 - 01:35 PM
In a real case of a gas processing plant, turn down case is 30 to 33%. Maximum throughput is 110%. This is valid for most of the gas sweetening, Gas dehydration and Sulfur recovery plant. 10% turn down as Napo told is quiet difficult to operate a plant. What you describe in your query, it contains fractionation Column, Pumps, Compressors etc. For rotating equipements you my have recycle, but for static equipments should have a minimum hydualic balance, else they will not work or poor performance. I will suggest to go for a specific case by case instead of getting general idea. Reducing turndown to 20-25% need modification of major equipements.
Edited by pronab, 16 April 2017 - 01:37 PM.
