No. Of Crosspasses
s&t exchanger
#1 john cardona
john cardona
  • 5 posts
Posted 03 May 2017 - 02:30 PM
Dear to all
Would you be so kind as to clarify, what is meant by the term "No. of Crosspasses" on Data Sheet of Heat Exchanger
Is this term related with the number of baffles perpendicular to the flow?
Thanks very much
#2 srfish
srfish
  • 408 posts
Posted 03 May 2017 - 07:59 PM
Crosspasses is a term that HTRI uses. It identifies the different characteristics of baffles.
#3 SASU
SASU
  • 3 posts
Posted 07 September 2017 - 08:36 PM
No. of Crosspasses = No. of baffles + 1
#4 Pilesar
  • 1,700 posts
Posted 08 September 2017 - 09:31 AM
As the fluid travels through the shell side of a shell and tube exchanger, it passes nominally perpendicular across the tube bundle because the baffles partially block the flow. The fluid changes direction when it gets to the other side of the baffle and travels perpendicular to the tubes in the opposite direction. Each time the fluid passes perpendicular to the tube bundle is a crosspass.
#5 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 03 January 2018 - 04:57 AM
Dear to all
Thanks very much
Yes, cross pass and baffles are related to each other. Crosspass count is higher by 1 over the baffle count.
