What is the difference between cut point and end point. what is the effect of steam rate and other parameters like pressure on end point?
What Is The Difference Between Cut Point And End Point? What Is The Ef
Posted 14 May 2017 - 04:29 AM
Posted 23 May 2017 - 12:16 PM Best Answer
Hassamullah,
You can review the ASTM D-86 standard.
Initial Boiling Point (IBP), in D86 distillation, the corrected temperature reading at the instant the first drop of condensate falls from the lower end of the condenser tube.
End Point (EP) or final boiling point (FBP), the maximum corrected thermomether reading obtainend during the test.
Cut points, is the evaporated point to 5%, 10%, 20%, 30-70%, 80% 90% 95%.
More pressure, more high EP (heavy)
More steam, more high EP (heavy).
Napo.
Posted 26 May 2017 - 10:19 PM
For a TBP, EP and cut point are the same. ASTM has tails, and EP does not equal cut point. Stripping steam reduces the tails of the ASTMs of the two streams.
Chemical Injection PointStarted by Guest_Lyne_* , 15 May 2024 |
What Is The Difference Between Api 521 Sixth Edition & Seventh EdiStarted by Guest_Murtaza Lashkerwala_* , 13 May 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Increasing Raw Natural Gas Dew PointStarted by Guest_lowrentstuff_* , 18 Sep 2023 |
Dew Point Margin In Strippers & Fractionation ColumnsStarted by Guest_Venkat @89_* , 05 Sep 2023 |
