How To Determine The Heat Transfer Coefficient
heat transfer coefficient
#1 August
August
  • 38 posts
Posted 26 June 2017 - 10:38 AM
I am looking for heat transfer coëfficiënt for the heat exchanger.
But from the common table, this values are normally within a very large range. for example,
water : 500-10000 w/m2.k
Is there an equation or something that can determine this coëfficiënt accurately?
Thanks in advance.
#2 srfish
srfish
  • 408 posts
Posted 26 June 2017 - 11:29 AM
There is not a single equation that calculates the overall heat transfer equation. Check out any book on Process Heat Transfer and they show the equations to calculate this..
#3 Mahdi1980
Mahdi1980
  • 182 posts
Posted 28 June 2017 - 01:26 AM
Please let me know what your major is.
As Srfish said, you cannot exactly determine the heat transfer coefficient without knowing the fluids , their physical properties as well as flow rates  (velocities) and the material of tube.
There is not a simple equation. You should first calculate the Reynolds, Prandtle and Nusselt numbers to determine the convectional coefficient.
Edited by Mahdi1980, 28 June 2017 - 01:27 AM.
#4 August
August
  • 38 posts
Posted 28 June 2017 - 04:42 AM
I should put my question in this way: I am looking for the equations to calculate the accurate convective heat transfer coefficient.
Yes, I do have all the physical properties of the fluids and process data, etc. What I need is the equations that can relate all this values and generate the specific convective heat transfer coefficient.
Could you please indicate which books that I can use?
Thanks.
#5 Mahdi1980
Mahdi1980
  • 182 posts
Posted 28 June 2017 - 05:22 AM
You can find the equations in books like " Heat transfer, by Holman" and Perry's chemical engineers handbook ( Heat transfer chapter).
#6 breizh
  • 6,769 posts
Posted 28 June 2017 - 06:11 AM
To start with .
hope this is going to help you.
#7 August
August
  • 38 posts
Posted 28 June 2017 - 07:38 AM
Many thanks.
