Why in turbine, we have to place axial compressor no centrifugal compressor ?
Thank you.
Posted 09 July 2017 - 05:01 AM
Thank you.
Posted 09 July 2017 - 09:35 AM Best Answer
The answer, of course, is "Because it's best". If you are a student, you should find information about gas turbines. And look for information on axial and centrifugal compressors.
Posted 03 August 2017 - 08:00 AM
Yes Bobby,
May be the mais reason is the axial compressor can ensure an important airflow and pressure rate ?
Parallel Compressor Setup With Uneven CapacitiesStarted by Guest_sinrem_* , 13 May 2025 |
Centriugal CompressorStarted by Guest_Rahimzadeh_* , 02 Mar 2025 |
Pulsation Device In Reciprocating CompressorStarted by Guest_zaidanamir_* , 17 Feb 2025 |
Recip Compressor Discharge PrvsStarted by Guest_go-fish_* , 15 Oct 2022 |
