Reboiler Tube Rupture And Normal Condensing Duty
#1 solnoid
solnoid
  • 4 posts
Posted 11 July 2017 - 09:17 AM
I'm looking at the relief valves on several distillation columns and in particular, the case of a reboiler tube rupture. I'm wondering if it is acceptable to take credit for the normal condensing duty of the overheads condenser during a tube rupture failure. It is my belief that losing cooling water to the overheads condenser and having a reboiler tube rupture would be considered double jeopardy.
Are there any precedents or code implications that would prevent me from doing so? I have not encountered any yet in my research. Thanks.
  • 1,635 posts
Posted 11 July 2017 - 10:10 AM
Assuming normal condensing UA is reasonable for reboiler tube rupture case. You should not take credit for condenser U higher than U(service). Condensing duty can be recalculated for conditions at the relieving pressure so this likely results in a higher condensing duty credit than 'normal.'
#3 Pilesar
  • 1,635 posts
Posted 13 July 2017 - 03:12 PM
Thinking more about my answer, it may not be conservative enough. If you have a turndown case for your overhead condenser, you should use that to constrain your condenser duty credit. You may have a reboiler tube rupture when you are operating the condenser turned down.
#4 spchauhan12
spchauhan12
  • 43 posts
Posted 28 July 2017 - 01:53 AM
Dear  solnoid,
Kindly have a look into API 521 section : Individual Overpressure Causes and Their Relieving Rates.
SPC
