I need information about the calculation to the mass transference coefficients in a distillation packed column, tested with binary mixed (ethanol-water). Then, calculated HETP and simulate it like a tray tower.
So , if someone knows a method to modeling a distillation packed column based in diffusivities models; please, indicate me how do it.
Carabobo, Venezuela. (Carabobo University)
Packed Column Distillation
Started by oscar, Aug 10 2006 03:19 PM
Posted 10 August 2006 - 03:19 PM
Posted 11 August 2006 - 08:57 AM
I don't know your background and knowledge, but assuming you have done the obvious web searching and library searches, you might read http://www.gch.ulava...owers/hetp.html to see if it is of any use. At http://www.gch.ulaval.ca/bgrandjean/ you can find more articles by the same author.
