Relation Between H2/ Feeddstock Qualite In Catalytic Reforming Process
Posted 13 August 2017 - 06:10 AM
Posted 23 August 2017 - 12:54 AM
If you are referring to purely from the Reformer, the gas product H2 purity is definitely a function of feed composition. If you have higher naphthenes and aromatics (measured by N + 2A) definitely your reformate yield is higher and thus there is less production of cracked gas. This cracked gas (C1-C5) comes together with the H2. As you can expect, a more paraffinic (straight chain) will give you more gases.
However Reformers are usually equipped with an LPG recovery system to recover this C1 to C5 and then there is a PSA unit to purify the H2 to a very pure H2 product. Therefore, regardless of the feed composition, if you have a PSA unit you will be able to get a very pure H2 product. What might change is not purity but the quantity.
Posted 19 November 2022 - 10:05 AM
Hi, everyone, i have a question , are there any relations between the purity of hydrogen produced by the catalytic reforming process and the Feedstock used (qualite, densite...)(books, references...).
Best regards.
Posted 21 November 2022 - 03:31 AM
As colt mentions more cracking will lead to higher levels of methane production which is what has the biggest impact on H2 purity. Some units have refrigeration to knock out LPG, some don't. Generally the net hydrogen gas is used to hydrotreat naphtha so i'm curious why you would alter feed type to try and imporve Hydorgen purity?
Mastered Process EngineeringStarted by Guest_Boudinahh8777_* , 31 Oct 2025 |
Gas Sweetining ProcessStarted by Guest_Alameerha_* , 10 Nov 2025 |
Seeking Feedback On My Process Flow Diagram. Biogas Steam Reforming ToStarted by Guest_Jacobaum_* , 27 Oct 2025 |
Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
Any Ways Or Where To Find The Licensor Process?Started by Guest_adrianong_* , 19 Sep 2025 |
