Dear all
I would like to consult you about the control valve.
My control valve was design at below condition
Flow rate(m3/h) : max. = 79.1, Nor. = 79.1, Min. 37.2
Inlet press.(kg/cm2g) : max. = 61.9, Nor. = 61.9, Min. -
Diff press.(kg/cm2) : max. = 2.8, Nor. = 2.8, Min. -
Temp(degC) : max. = 320, Nor. = 312, Min. 300
Cal. CV : max. = 45.74, Nor. = 45.74, Min. 21.50
Rated CV : 165
How can I calculate when control valve open 100%op?
Best regards,
Salapao.
