Does anyone know the name of the algorithm that is used in VMGSim/Hysys for allowing bi-directional transfer of properties? Or have any references to published papers on the subject?
Bi-Directional Algorithm In Hysys/vmg Sim
Posted 16 August 2017 - 11:37 AM
Posted 16 August 2017 - 02:15 PM
You should find the answer on the program licensor's support site. Or, contact them.
Posted 17 August 2017 - 02:37 AM
It's really not the sort of information they like to publicize.
Posted 17 August 2017 - 10:01 AM
what do you mean with bi-directional transfer of properties ?
solving recycles ? all simulators are able to do that with different algorithms,
selection depending from specific application.
Posted 17 August 2017 - 10:58 AM
Simulators are typically either sequential modular and all properties flow uni-directionally through the flow sheet, including recycles, or they are EO based in which case all equations are solved simultaneously.
However with Hysys, Unisim, Petrosim, VMGSim, which all have similar origins, information, e.g. properties, can flow in two directions both upstream and downstream at the same time, i.e. they are bi-directional.
It is this bi-directional algorithm i am interested in getting information on.
Posted 17 August 2017 - 12:38 PM
no, there are hybrid solvers and there are papers discussing details (see Lucia etc.)
for example you can detect the sections which must be recalculated and solve only a subset,
some units (flash operations etc.) can be solved in two ways,
others (columns, reactors etc.) not,
etc. etc.
Posted 17 August 2017 - 03:55 PM
Posted 18 August 2017 - 01:23 AM
it's a complex problem and different products (from Hyprotech, Simsci, GProms, Prode etc. etc.) proposed different solutions,
an efficient solution requires proper initialization of variables, identification of sequence and units to solve, local / global convergence etc.
many simulators include different solvers, allow to initialize variables etc. etc.
for simple problems I have tested global search with multistart solvers (Matlab toolbox), ok but slow (not efficient, in general).
Posted 18 August 2017 - 03:13 AM
Does anybody have any actual information on the bi-directional algorithms employed by several of these simulators?
#10
Posted 28 August 2017 - 08:43 AM
Each object has its own self-contained solution code, and the solver is nothing more really than an event handler that builds and runs through stacks of objects and tells them to solve themselves over and over for as much as they can each time. The system is built so that whenever new information is calculated into an object (a stream or a unit operation) then that object and its attached objects get pushed onto the solver stack again and the process repeats until no more new information can be calculated. Roughly speaking.
#11
Posted 28 August 2017 - 11:39 AM
DarrenO,
thanks for the contribute,
possibly the solver in the sim42 code mentioned by StealthProg works in that way,
that would confirm there was some misinterpretation about the meaning of bi-directional algorithm,
Edited by serra, 28 August 2017 - 11:58 AM.
#12
Posted 28 August 2017 - 12:00 PM
Bi-directional in terms of the heritage Hyprotech simulators means that information can be specified anywhere in the flowsheet and will eventually work its way up or downstream as needed to satisfy individual unit operation degrees of freedom until they all solve. One sample case that ships with all the HYSYS flavours involves a piping network where composition is specified at the very downstream end of the pipe network, the non-sequential modular solver allows this composition to be calculated backwards all the way back to the most upstream pipe, where it then fills out the degrees of freedom for that pipe to start pressure calculations going forward along the flowsheet until the flowsheet is fully solved. It isn't a true EO solution (as it isn't solved simultaneously), but it is bi-directional in terms of information flow allowing the solver to fill in bits as necessary.
I don't know anything about VMG-SIM, but I would assume it is similar as it is all ex-Hyprotech developers that wrote it.
#13
Posted 29 August 2017 - 01:51 AM
Stealthprog,
can you explain the red flag to post #8,
where I mention Hyprotech, Simsci, GProms, Prode etc. including solvers with similar features (meaning, for example, the capability to solve a pipeline from end, etc.) ?
As said in post #6 hybrid solutions allows to switch from local to global solvers in order to improve efficiency (time savings),
you can solve sequentially (in two ways) some units (for example a series of H-P flash to model a pipeline with heat transfer) but for other units (columns, reactors etc.) as far as I know hybrid solutions are more efficient.
#14
Posted 27 March 2019 - 06:01 PM
can some body tell me how I can read VMG simulation file in Hysys, if thats possible.
What is the procedure..
Need urgent support.
Muhammad Naeem
MEng (Specialization Energy & Environment)
Schulich School of Engineering
University of Calgary
#15
Posted 18 April 2019 - 02:58 AM
Muhammad Naeem
perhaps you will be dissapointed
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
