Hello everyone,
I would like to ask you if you could share with me commercial applications for hydrodesulfurization of heavy residue?
Thank you in advance
Posted 16 August 2017 - 06:05 PM
Hello everyone,
Posted 16 August 2017 - 11:28 PM
Are you looking for a list of operating units or a discussion comparing the application to a middle distillate application, for example?
Posted 17 August 2017 - 08:39 PM
By 2020, the IMO has regulated that sulfur content used as bunker fuel must be 0.5wt% S so there is the commercial application issue resolved I would think.
Posted 19 August 2017 - 07:19 AM
My question is mostly how we can treat the heavy residue after the vacuum distillation. My question is if you belive if with a hydrotreater and simple hydrodesulfurization is possible to achieve these specifications? Because in the ehavy residue this refractory sulfur components are difficult to be treated.
Also if a combination of hydrodesulfurization and hydrocracking units are a better choice to meet the specifications in bunker fuels?
Thank you in advance!
Posted 20 August 2017 - 04:08 AM
Basically you can count on the following main hydrogen addition technologies, already applied to Vacuum Residues:
- LC-Fining, from CLG (Chevron Lummus Glabal)
- H-Oil, from Axens
- EST (ENI Slurry Technology), from ENI Technologies
All of them provide Hydrocracking other than Hydrodesulfurization.
They can also be applied after a Solvent Deasphalting of the Vacuum Residue that would reduce the capacity/cost.
You can easily imagine the very high CAPEX and OPEX required for this kind of plants.
good luck!
Posted 20 August 2017 - 12:38 PM
All these methods are used for hydrocracking, however the presence of sulfur in these streams do not affect the catalysts that used in hydrocracking reactors?
For example ENI technology is a technology, which can provide simultaneously sulfur reduction and hydrocracking by using dispersed catalysts or it is required a step before the hydrocracking in which the sulfur will be reduced?
Posted 20 August 2017 - 11:03 PM
(Some) details ot the various technologies are published: please kindly refer to them directly in order to avoid biased info.
But, generally speaking, there are steps of HDS (and HDN) before, after and concurrently with the HCK. Otherwise, it would be impossible the deep reduction of Sulfur in the liquid products with respect to the feed....
Hydrodeoxygenation Of Kerosene Before HydrodesulfurizationStarted by Guest_abdoolali_* , 24 Oct 2025 |
Calentamiento De Bunker 6(Combustóleo Con Calentador De Inmersión)Started by Guest_manuelh_* , 07 Aug 2017 |
Hydrodesulfurization Of Fuel OilStarted by Guest_sheida_* , 26 Feb 2017 |
Liquid Transportation Fuels From Natural GasStarted by Guest_cristinasabo_* , 17 Feb 2014 |
Filtration Of Petrol Related Fuels, How Does It Work?Started by Guest_Dijkman_* , 12 Aug 2013 |
