Temporary Strainer At Pump Suction
strainer pump
#1 ezralh
ezralh
  • 32 posts
Posted 13 September 2017 - 10:22 AM
Dear Experts,
What happen if we did not remove  temporary strainer that we installed during start-up?  The temporary strainer (conical)  was installed at pump suction.
#2 latexman
  • 1,922 posts
Posted 13 September 2017 - 10:44 AM
It could eventually get dirty/plugged and cause problems (cavitation), or if it's a clean, non-corrosive service all it'll cost you is the pressure drop/power for the life of the pump.
#3 chocobang
chocobang
  • 65 posts
Posted 13 September 2017 - 05:59 PM
From experience, I think many clients tend to forget to remove this temporary strainer.
As a process engineer, we don't usually pressure drop in the pump calc because the intent is removing it after the first shutdown.
As latexman correctly pointed out, if the TS is not removed, pressure drop will occur which eats up some NPSHa.
