I am studying a 750 km pipeline in order to detect if there is any surge pressure caused by a sudden valve closure. I have been given assignment to design a surge tank.
I highly appreciate if someone can help me how to start.
Thanks a lot
Posted 12 October 2017 - 12:01 PM
Posted 12 October 2017 - 12:57 PM
Hi Mehdi,
At first let's know the detail of the pipeline and the reason(s) based on which you recognized the necessity of considering a surge tank for protection of mentioned pipeline.
Posted 12 October 2017 - 02:18 PM
There is no pipeline in the world that is continuous for 750 km. Whether liquid, dense phase, or vapor, there will be breaks with compressors or pumps. Maybe you meant 75 km?
Posted 13 October 2017 - 09:51 AM
Hi FALLAH,
It's a 750 km pipeline with a six pump stations, pipeline material carbon steel with grade used X60, X65
dn = 12 in, wall thickness = 0.25 in and transporting hydrocarbon fluids.
Example for the surge event that i noticed:
I have a pump station at x = 490.5 km with P = 85 bar (discharge pressure), the valve located at x=494.25 km closes in t=12 sec
The pressure registered in the upstream of the valve (Pmax= 142 bar) exceeds the Maximum Allowable Surge Pressure of the pipeline (MASP)
Therefore to prevent this problem I have to plant a surge tank
Bobby:
Mehdi
Posted 13 October 2017 - 01:07 PM
You should enlist the services of a professional who can lead you to the proper solution. It might be as simple as changing the valve(s) stroke time.
Posted 14 October 2017 - 04:47 AM
Hi
I had tried to change the valve stroke time before. but this solution is not relevant in some cases, for example :
- In an emergency shutoff
- Or when the stroke time should be upper then one and half minute to avoid the surge event.
therefore the remain solution is to plant a surge tank in the upstream of the valve
Mehdi
![]() Atmospheric Tank Vent SizingStarted by Guest_kmic_* , 30 Sep 2025 |
![]() Storage Tank Relief LoadStarted by Guest_hum464_* , 10 Sep 2025 |
Refrigerated Storage Tank Vaccum Breaker CapacityStarted by Guest_Lyne_* , 13 Sep 2025 |
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
