Can anybody have idea what is purpose of Gas to Air ratio Interlock in secondary reformer in Ammonia Plant??
Gas To Air Ratio Interlock In Ammonia Plant
Started by Riaz01, Oct 13 2017 03:14 PM
Posted 13 October 2017 - 03:14 PM
Posted 15 October 2017 - 12:33 AM
There is a saying "the best way to obtain a correct answer in a forum is not to ask for it, but to state the wrong answer".
In this case, is the same. Please risk an opinion. Do some thinking. People around here will help if you are heading in the wrong direction.
Why do you think you should limit the ratio of air and gas?
Posted 21 November 2017 - 12:24 AM
Air to gas ratio is there to prevent overheating the secondary reformer and damaging the vessel and catalyst.
The adiabatic flame temperature increases with air to gas ratio.
Benfield Solution For Ammonia PlantStarted by Guest_Chemist Ahmed_* , 03 Dec 2023 |
Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
