Can a centrifugal compressor be run with antisurge valve open continuously to achieve capacity control?
Permanent Recycling In Centrifugal Compressor
Started by apex, Oct 26 2017 10:27 AM
Posted 26 October 2017 - 10:27 AM
Posted 26 October 2017 - 11:09 AM
In general, i think if the discharge air cooler/exchanger is operating during recycling; there would be no problem.
Posted 26 October 2017 - 06:30 PM
It all depends on the fluid that is handled, and if the system is designed for sustained recycle for control. There is no yes/no answer with no information. Although Naser has provided a qualified answer.
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
