Negative Logic Diagram
process control control narrative negative logic
#1 mes127
mes127
  • 3 posts
Posted 02 November 2017 - 11:15 AM
Hello Everyone,
Our EPC company asked to provide a control logic diagram based on process control narrative for a hydrocarbon processing plant. However, I was asked specifically the diagram should be prepared in "negative logic" format.
I did some internet search but there are limited sources on this, plus as a chemical engineer it makes more sense to me to see similar approach on a chemical process rather than other disciplines such electrical engineering.
I just wonder if someone could share with me with such a diagram for a typical unit operation with a few instruments?
Thank you
Max
#2 Pan Nata
Pan Nata
  • 34 posts
Posted 03 November 2017 - 04:12 AM
Hi Max,
I've never heard any kind of that document. For control logic, process/chemical eng. mostly deal with S.A.F.E charts, causes & effects matrix, and ESD Logic diagram.
#3 mes127
mes127
  • 3 posts
Posted 03 November 2017 - 05:30 PM
Pan,
The documents you mentioned are also part of the package, but Control Logic is also a stand alone document.
Thank you
Max
#4 Saml
Saml
  • 301 posts
Posted 03 November 2017 - 09:18 PM
As far as I know, "negative logic" means that low voltage means true, while high voltage means false.
This makes sense when you want to consider the loss of signal as a "true" value signal for an alarm or a switch that activates a logic.
But it may also mean writing the logic in the negative forms like A_AND_B = Neg(NegA_OR_NegB)
Say
Positive AND
True-True = True
True-False = False
False-True =False
False-False = False
equals to
Negative OR
False-False (Negative of True-True) = False (Negative is True)
False-True (Negative of True-False) = True (Negative is False)
True-False (Negative of False-True) = True (Negative is False)
True-True (Negative of False-False) = True (Negative is False)
Also Check This
http://hyperphysics....ic/gate.html#c2
#5 breizh
  • 6,939 posts
Posted 05 November 2017 - 07:53 AM
hi ,
training materials are available on Youtube .
Good luck.
#6 mes127
mes127
  • 3 posts
Posted 06 November 2017 - 03:26 PM
Thank you everyone for your feedback.
Max
