Loss Of Pump Discharge Pressure
pump flow pump suction design troubleshooting
#1 emma14778
emma14778
  • 10 posts
Posted 23 November 2017 - 01:29 PM
We have a water pump which has about 90% of its feed from one source (Stream A) and 10%  from another (Stream B). There is a tee about 5m before the suction of the pump.
Recently we had a failure on stream B which resulted in losing the full 10% flow. There were minimal changes in suction pressure but we lost 40% of our discharge pressure and flow dropped by about 20%. As far as I can tell we didn't reach any cavitation, the NPSHr (0.8m) is significantly lower than the NPSHa (13m).
Is it expected that a sudden loss of 10% of your feed would result in such drastic discharge pressure loss and loss in flow? I would have expected to temporarily lose the 10% of the flow but no more. Can this be defined as cavitation or is it something else I am unaware of? The main source of liquid comes from a vessel which has enough inventory to compensate for the loss in flow.
Emily
#2 villivord
villivord
  • 13 posts
Posted 23 November 2017 - 02:56 PM
You mention a flow reduction of 20%. Look at the relationship between pressure drop and flow (Darcy-Weisbach) which will explain the 40% reduction in discharge pressure. This can also be seen from your system curve, if available. The minimal changes in suction pressure sounds logic as I assume the system between the sources and pump is small compared to the system on the discharge side.
How do you know source B is only 10% of the incoming feed?
Edited by villivord, 23 November 2017 - 03:01 PM.
#3 Bobby Strain
Posted 23 November 2017 - 05:55 PM
If you post a sketch with details maybe someone can help. And pump information.
Edited by Bobby Strain, 24 November 2017 - 10:23 AM.
#4 breizh
  • 6,934 posts
Posted 25 November 2017 - 04:38 AM
HI Emily,
You can download for free on internet PSIM , a nice software to simulate your system .
I's a great tool , you can build your system using the examples available and test different cases.
http://www.aft.com/psim
Hope this could help you .
Good luck.
Edited by breizh, 25 November 2017 - 05:01 AM.
#5 spchauhan12
spchauhan12
  • 43 posts
Posted 25 November 2017 - 05:34 AM
Dear Forum members,
                       Is System Curve required for AODD Pump (Air- operated double diaphragm Pump)  ?
As per my knowledge, I know this is required for Centrifugal Pump to find out resistance in flow system for corresponding flow values for a
given pipe size.
I have done many Hydraulic calculations for Centrifugal Pumps & AODD Pump in my past porjects, but never drawn system resistance
curve for AODD Pump.
Any co-operation towards this end would be highly appreciated.
SP
