Dear All
Using OLGA steady state fonction to perform simulation of multiphase pipeline (oil gas and water). the model required to dividing the line into 50 segments corresponding to the changes in elevation of the pipeline profile. The Peng-Robinson equation of state calculated thermodynamic properties.
The same configuration was used in Pipesim software
The Beggs-Brill correlation predicted pressure drop in Pipesim, with total pressure drop equal to the summation of friction loss , elevation change and velocity change.
The simulations results displayed a similar overall pattern but a large difference in the results was shown in term of Pressure Drop through the pipeline
Can you explain please the origine of this difference between the two softwares ???*
