Light Hydrocarbon Flashing Through A Psv
10 replies to this topic
#1 J_Leo
J_Leo
  • 262 posts
Posted 30 November 2017 - 03:49 PM
Dear Friends,
I have light liquid hydrocarbon (C3,C4) to relieve through the PSVs, for block outlet case. Some flashing is expected for some PSVs. To what extent, do we need to use the two phase methods? If only a very small fraction of flashing, can we use liquid equations? I have done this before, now, I want to get your opinions.
Thank you,
-Leo
#2 fallah
  • 5,026 posts
Posted 30 November 2017 - 03:54 PM
Dear Friends,
Thank you,
-Leo
Leo,
IMO, for very small fraction of flashing there would be no problem using liquid equation...
#3 J_Leo
J_Leo
  • 262 posts
Posted 30 November 2017 - 04:01 PM
Fallah,
Thank you. Do you have a rule of thumb about the "small amount"?
Leo
#4 fallah
  • 5,026 posts
Posted 30 November 2017 - 04:07 PM
Leo,
No specific rule of thumb, but a few percent flashing fraction, say below 5% ...
Edited by fallah, 30 November 2017 - 04:18 PM.
#5 latexman
  • 1,893 posts
Posted 30 November 2017 - 04:54 PM
I think it depends on how long the outlet line is.  If the outlet line is short, more.  If the outlet line is long, less.
#6 Bobby Strain
Posted 30 November 2017 - 05:31 PM
There is no reason NOT to size as a flashing liquid. It's a simple enough calculation. HEM method is readily available. And you can use your process simulator for flashing. VMG simulator has the capability built into the simulator.
#7 J_Leo
J_Leo
  • 262 posts
Posted 30 November 2017 - 09:14 PM
Fallah, Laxeman, and Bobby,
Thank you very much for your advice. The only problem is there is limited access to the simulation software with my current employer. The big oil and gas downturn has made my work environment worse than before. I really hope everything will go back to normal soon.
-Leo
#8 Bobby Strain
Posted 01 December 2017 - 12:12 AM
So, post the composition along with relieving rate and temperature and set pressure and I'll reply with a required size using the HEM procedure. Then you can compare it to an alternate sizing method of your choice. Maybe someone else will also respond, too. Many have good software at no cost. But remember, it's your responsibility.
#9 serra
serra
  • 311 posts
Posted 01 December 2017 - 02:07 AM
Leo,
about your question (PSV design for flashing liquid) there are several equilibrium and non-equilibrium models available,
see for example this thread
https://www.cheresou...-design-rating/
HEM model should revert to standard model for the cases of all liquid or all gas
but for gas it results more accurate than standard model (integration with real properties)
#10 J_Leo
J_Leo
  • 262 posts
Posted 25 February 2018 - 09:40 PM
Hi All,
I just want to give an update. I have used the two-phase flow equation from API 520 Part I to calculate the orifice size. Compared to using single liquid phase, the orifice size using two-phase equation is even smaller though there is significant flashing through the orifice. I think the reason is: Kd of 0.65 is used for liquid sizing and Kd of 0.85 is used for two-phase. Smaller Kd gives a bigger orifice size. Only when the fraction of flashing exceeds a certain value, the orifice size will be bigger using two-phase equation.
-Leo
#11 serra
serra
  • 311 posts
Posted 26 February 2018 - 11:55 AM
Leo,
if I remember correctly Kd should be the effective coefficient of discharge, the values 0.85 and 0.65 are given for preliminary sizing,
anyway I agree that Kd has a large influence on required discharge area,
you may find useful also this thread
https://www.cheresou...r-2-phase-flow/
